Home :: Washers, Spacers, Springs, Nuts & Bolts :: Sleeves / Steering Spacers :: Stub Axle Spindle Kingpin Spacer Washer 3.5mm Thick 8mmID
BRAND NEW spacer for Stub Axles.
Fits between stub axle bearing and clamp.  Tapered lip to suit 12mm top and bottom holes.
Inner Diameter 8mm suit M8 Kingpins
Outer Diameter 20mm
Thickness 3.5mm
(2.5mm thick base washer with a 1mm high inside flange - flange can be filed down to suit overall required thickness)
Stub Axle Kingpin Spacer Washer 3.3mm Thick 8mmID
33%
SKU SSWC01
