Home :: Steering Components :: Shafts & Tie Rods :: Steering Tie Rod Pair Silver Anodised Alloy Hex M8 8mm 240mm x1 & 260mm x1
ABSOLUTELY BRAND NEW pair of steering tie rods.
THIS SET OF RODS IS A STAGGERED PAIR TO SUIT CPR KARTS FROM 2019 on
240mm rod is used for the left side of the kart and 260mm is used for the right side (when viewed from the rear of the kart)
Premium quality hex extruded alloy tie rods.  Our tie rods are the best in the business, designed for race karts where strength, weight and integrity are critical to the performance of your vehicle.
Our rods offer outstanding value.
LHS thread side is grooved for immediate and easy identification.
The centres of our rods are drilled through ready to tap easily.  If you need to shorten a rod, cut it on the RHS (the side without the groove) - the thread protrudes around 30mm into the rod on each end.
- 2x Tie Rods Silver Hex Alloy Anodised - length as per title.
SKU STRPC3_KARTKIT
