Home :: Steering Components :: Shafts & Tie Rods :: Steering Tie Rod Pair Gold Anodised Alloy Hex M8 8mm 255mm
ABSOLUTELY BRAND NEW pair of steering tie rods.
Premium quality hex extruded alloy tie rods.  Our tie rods are the best in the business, designed for race karts where strength, weight and integrity are critical to the performance of your vehicle.
Our rods offer outstanding value.
LHS thread side is grooved for immediate and easy identification.
The centres of our rods are drilled through ready to tap easily.  If you need to shorten a rod, cut it on the RHS (the side without the groove) - the thread protrudes around 30mm into the rod on each end.
- 2x Tie Rods Gold Hex Alloy Anodised - length as per title.
Clic the picture below to view the tie rod measuring guide to assist in determining the correct size for your kart.
53%
SKU STRPC5255
