Home :: Steering Components :: Shafts & Tie Rods :: Tie Rod Kits Complete :: Steering Tie Rod Assembly SILVER Pair Complete w/Purple Brand New
ABSOLUTELY BRAND NEW complete steering tie rod assembly! Bolt-on and GO!
*NEW MODEL* - Now in lightweight hex alloy with many different lengths available!
Comes with everything you need to connect it up and use. PLUS FREE countersunk washers, bolts and nuts!!!!!
As per the pictures, included in the pack:
- 2x Tie Rods (Choose your length by clicking "Configure" at the bottom of this ad) Silver
- 2x LH Tie Rod Ends
- 2x RH Tie Rod Ends
- 2x LH lock nuts
- 2x RH lock nuts
- 4x Countersunk washers (Colour and type as per picture or you can change this in the specification after clicking "Configure" below)
- 4x Bolts
- 4x Washers
- 4x Nyloc nuts
(Depending on tie rod length chosen - select by clicking "Configure" below):
SKU STRPKSP
Base product price: $59.95
