Home :: Steering Components :: Shafts & Tie Rods :: Steering Shaft 20mm (Long)
20mm OD Steering Shaft
(Long Model)
This shaft comes with 2 holes in the dual plate bracket to allow side by side mounting of tie rods.  You can either use the top, or bottom, or both brackets for mounting with or without spacers.
Total length of the shaft can be reduced by removing material from the top of the shaft and re-drillig the boss hole.  Only one hole in the shaft is required for most boss systems.  A second hole may be offered in some boss units but is not necessary.
Dimensions:
Dimension A: 545mm
Dimension D - Bottom of shaft (Bottom of A) to bottom bracket Tie Rod Holder (where B&C Meet) = 70mm
Dimension Unassigned - Bottom of shaft (Bottom of A) to top bracket = 100mm
Click the picture below to view the tie rod measuring guide to assist in determining the correct size for your kart.
SKU SSHC2B
