Home :: Steering Components :: Shafts & Tie Rods :: Steering Shaft 20mm
Steering Shaft 20mm
Steering Shaft 20mm
20mm OD Steering Shaft
Our shaft comes with 3 holes in the dual plate bracket to allow either side by side or central mounting of tie rods.  You can either use the top, or bottom, or both brackets for mounting with or without spacers.
Total length of the shaft can be reduced by removing material from the top of the shaft and re-drillig the boss hole.  Only one hole in the shaft is required for most boss systems.  A second hole may be offered in some boss units but is not necessary.
Dimensions:
Dimension A: 480mm
Dimension D - Bottom of shaft (Bottom of A) to bottom bracket Tie Rod Holder (where B&C Meet) = 75mm
Dimension Unassigned - Bottom of shaft (Bottom of A) to top bracket = 105mm
Distance between tie rod mounting brackets = approx 28mm
Click the picture below to view the tie rod measuring guide to assist in determining the correct size for your kart.
27%
SKU SSHC20
