Home :: Steering Components :: Shafts & Tie Rods :: Steering Shaft 19mm Midget/Rookie Short
19mm OD Steering Shaft
 Short - suit midget/rookie chassis including CPR midget/rookie karts.
Our shaft comes with 2 holes in the plate bracket to allow either side by side mounting of tie rods.
Total length of the shaft can be reduced by removing material from the top of the shaft and re-drillig the boss hole.  Only one hole in the shaft is required for most boss systems.  A second hole may be offered in some boss units but is not necessary.
Dimensions:
Dimension A: 325mm
Dimension D - Bottom of shaft (Bottom of A) to bottom bracket Tie Rod Holder (where B&C Meet) = 40mm
Dimension Unassigned - Bottom of shaft (Bottom of A) to top bracket = 90mm
45%
SKU SHFM19
