ABSOLUTELY BRAND NEW complete steering assembly! Bolt-on and GO! NEW MODEL - Includes Steering Column STOP Collar (Anodised Black) and bolt kit to fit column to chassis!
COMPLETE FROM BOSS TO NUT Everything you need is in the kit - all the nuts, bolts, washers, and bush! Just add your steering wheel (or add one from our store)
WIDE RANGE OF COLOURS Our kits are in stock and available with coloured countersunk washers in Gold, Blue, Red, Black, Purple or Silver! This listing is for the colour pictured.
RACE KART BOSS Our included bosses offer standardised PCD's to suit almost all race kart steering wheels. You'll be sure your current wheel will bolt up! (Holes centres are set 41mm from each other)
1x Steering BOSS (standard race kart steering wheel boss - 1x Anodised Steering Column Stop Collar 1x Nylon Steering Bush (NOT PICTURED, BUT SUPPLIED) 1x Steering Bush High Tensile Bolt , Nyloc & Washer Dimension D - Bottom of shaft (Bottom of A) to bottom bracket Tie Rod Holder (where B&C Meet) = 75mm Dimension Unassigned - Bottom of shaft (Bottom of A) to top bracket = 105mm Click the picture below to view the tie rod measuring guide to assist in determining the correct size for your kart. Not sure what length you need? Click here to view our guide and sizing grid. NOT SURE HOW TO BUY THIS ITEM? Click here to read our simple walk-through guide. |
| SKU | SRAC2P | |
| Base product price: |
$169.00
including GST 10% |
