Home :: Steering Components :: Shafts & Tie Rods :: Steering Assembly 20mm Base Kit
ABSOLUTELY BRAND NEW complete steering assembly! Bolt-on and GO!
NEW MODEL - Includes Steering Column STOP Collar (Anodised Black) and bolt kit to fit column to chassis!
Comes with everything you need to connect it up and use. PLUS FREE countersunk washers, bolts and nuts.  (See main pictures title for colour of washers)
Here's what you'd expect to pay for all the items separately on eBay:
BOSS - $34.99
1x Anodised Steering Column Stop Collar = $9.95
3x Boss Countersunk Washers Anodised (Colour as per Title) = $8.00
3x Boss Countersunk High Tensile Bolts & Nyloc Nuts = $6.00
SHAFT - $35.00
4x TIE ROD ENDS - $40.00
2x TIE RODS - $35.00
5x Tie Rod Countersunk Washers Anodised (Colour as per Title) = $12.00
4x Tie Rod Countersunk High Tensile Bolts & Nyloc Nuts = $12.00
1x Nylon Steering Bush (NOT PICTURED, BUT SUPPLIED) = $9.90
1x Steering Bush High Tensile Bolt , Nyloc & Washer = $4.00
Postage - Add Approx. minimum $75 individually from different sellers.
TOTAL VALUE = $206.85+POSTAGE = $281.85
Dimensions:
Dimension A: 480mm
(Depending on tie rod length chosen - select from the drop-down box below):
Bottom of shaft (Bottom of A) to Tie Rod Holder (where B&C Meet) = 60mm
SKU SRAC2
Regular price: $1066.55
