Home :: Sprockets & Chains :: 420 / 40 / 41 & 428 Pitch Chains Clutches & Sprockets :: Sprocket Split Machined Anodised Steel 420 41 Pitch 44 Teeth
(Split) 420 (41) Pitch Rear Drive/Axle Sprocket.
Holes are set 67mm apart from each other and 67mm from the centre (Suit Standard 219 or 35 pitch Sprocket hub).
44 Teeth.
Diameter approx 180mm
SKU SPR420
