**THIS IS A PRE-ORDER ITEM - ALLOW UP TO 5 DAYS FOR DISPATCH** Sprocket Guard 2-piece suit #35 219P 420 sprockets up to 190mm diameter
PETG printed protector - 193mm diameter Includes 2-piece protector (flexible - can install without removing sprocket or axle) and 6x 35mm High Tensile Screws, Nylocs, Washers.
Fits all CPR rear axle sprockets.
Standard 6-hole race kart pcd. WARNING: When fitting this item, ensure splits are located at opposite ends of the sprocket (180 degrees rotated). Also, splits should be fitted 90 degrees rotated from the split in a 2-piece sprocket. Failing to do this can weaken the guard and cause premature failure - it is not designed for sideways flex. It is also important to ensure there is enough clearance between the guard and the chain - some chain links may be wider than usual and can contact the guard which will cause chain bind, and may split or damage the guard.
Need to know the diameter, PCD, or hub diameter for a project? Click here for our complete gearing guide.
New. Click the condition meter to learn more about used items.
