Home :: Sprockets & Chains :: 219 Pitch Sprockets :: Sprocket Front (Rotax Max) 219 Pitch 11 Teeth
 Alloy 219Pitch Engine Sprocket.
Suits Rotax Max
10T and 11T sprockets are too small to use a roller-bearing style bush.  This sprocket uses a bronze bush - the bush can be found in the 'related products' tab below or you can search the store for the code: SBSG11
Number of teeth as per title.
SKU SPFR11
Bush to suit Sprocket Front (Rotax Max) 219 Pitch 11 Teeth (SPFR11)
$27.95
