Home :: Sprockets & Chains :: 219 Pitch Sprockets :: Sprocket Front (KT100 Short Shaft Red Clutch) 219 Pitch 11 Teeth with Bush & Bearing
Alloy 219 Pitch Engine Sprocket.
Suits KT100 Red Clutch (Short Shaft)
These fit all short shaft KT100 Red Clutch drums, even if your sprocket base has only the 4 holes and isn't completely round on the underside.  As long as your inner drum face is flat it won't foul.
219 Pitch
Number of teeth as per title.
*NOTE* This sprocket requires a bush and bearing (INCLUDED) to suit our 10T Short Shaft Red Clutch kit.
SKU SPFRSS11
