Home :: Sprockets & Chains :: 219 Pitch Sprockets :: Sprocket Front (Yamaha) 219 Pitch 10 Teeth suit Long Shaft
 *PLEASE NOTE:  MODERN DIRECT DRIVE SPROCKETS MAY NOT HAVE A KEYWAY - It is perfectly safe to use a non-keyed sprocket on your engine and it will not move as the taper will lock it in position securely.*
Alloy 219Pitch Engine Sprocket.
Suits Long shaft.
14mm Large Dia, 10mm small dia, Measured taper length 16mm
Number of teeth as per title.
KT100ShaftGuide
KT100ShaftGuide
Click here to learn how to identify KT100 shaft sizes)
Click here to read our simple walk-through guide.
SKU SPF105L
