Home :: Sprockets & Chains :: 219 Pitch Sprockets :: Sprocket Front (Yamaha KT100 and PRD RK100) 219 Pitch 10 Teeth suit Short Shaft
*PLEASE NOTE:  MODERN DIRECT DRIVE SPROCKETS MAY NOT HAVE A KEYWAY - It is perfectly safe to use a non-keyed sprocket on your engine and it will not move as the taper will lock it in position securely.*
Alloy 219Pitch Engine Sprocket.
Suits short shaft.
14.5mm Large dia, 12mm small dia, Measured taper length 20.5mm
Number of teeth as per title.
KT100ShaftGuide
KT100ShaftGuide
Click here to learn how to identify KT100 shaft sizes)
Click here to read our simple walk-through guide.
SKU SPF105S
