Home :: Axles & Parts :: Sprocket Carrier Hub suit 40mm Axle 8mm Keyway Silver
Brand new Rear Sprocket Hub / Carrier.
Suits axle diameter: 40mm
Keyway size: 8mm
SKU SHK408
