Home :: Axles & Parts :: 30mm :: Sprocket Carrier Hub suit 30mm Axle 6mmKeyway Billet Aluminium Gold Anodised Premium Hub
Brand new Rear Sprocket Hub / Carrier.
Suits axle diameter: 30mm
Keyway size: 6mm
Billet Aluminium
Gold Anodised premium Hub
SKU SHC306G
