Home :: Axles & Parts :: 25mm :: Sprocket Carrier Hub suit 25mm Axle 6mm Keyway Silver
 Brand new Rear Sprocket Hub / Carrier.
THIS MODEL HAS BOTH 6mm and 8mm keyways
Highest quality Aluminium component, designed and built with precision equipment.
Inner Diameter = 116mm
Suits axle diameter: 25mm
Keyway size: 6mm
SKU SHE256
