Highest quality - CNC - Anodised. RACE GRADE ITEM
Sprocket Hub/Carrier.
Suit 50mm Axle.
8mm Keyway.
The centre bore size of compatible sprockets is 116mm. The PCD Diameter is (6x) 132mm (centre of 6mm holes on opposite sides of sprocket)
