Home :: Axles & Parts :: Sprocket Carrier (Hub Only) suit 50mm Axle 8mm Keyway Black (Premium Competition Grade)
Highest quality Billet - CNC - Anodised.  PREMIUM COMPETITION GRADE ITEM
*NOTE: Current model has a satin finish rather than the gloss finish pictured*
Sprocket Hub/Carrier.
Suit 50mm Axle.
8mm Keyway.
SKU SHS508K
