Home :: Axles & Parts :: Sprocket Carrier (Hub Only) suit 40mm Axle 8mm Keyway Gold
Highest quality Billet - CNC - Anodised.
Sprocket Hub/Carrier.
Suit 40mm Axle.
8mm Keyway.
Colours as per title and pictures.
SKU SHC408G
