Home :: Washers, Spacers, Springs, Nuts & Bolts :: Sleeves / Steering Spacers :: Spacer 8mm Wide 8mmID Suit Steering Shaft Support and Tie Rod Support PK4
BRAND NEW Spacer 8mm Wide 8mmID Suit Steering Shaft Support and Tie Rod Support
Pack of 4pcs
Fits 8mm bolts that connect tie rods to steering shafts and bolts that connect the steering bush to steering uprights.
Inner Diameter 8mm suit M8 Kingpins
Outer Diameter 12mm
Thickness (length) 8mm
Spacer 8mm Wide 8mmID Suit Steering Shaft Support and Tie Rod Support - Pack of 4
SKU SPCRC88
