Home :: Clutches :: Smart Kart CPR Complete 1-inch 25.4mm Crankshaft Clutch Installation Kit WITH PISTON STOP (suit GX390) (Special Washer, Bolt, and Spacer)
The Smart Kart range includes all the necessary specialised hardware and tools to complete the installation of your new part so you can Drive Faster.
- 1x 1" Crankshaft Spacer (suit GX390) - goes between the clutch and the engine so your clutch doesn't foul on the crankcase cover which can cause failure of the clutch and or damage and injury.
- 1x Clutch Retaining Washer (extra thick 3mm and large OD 33mm) - goes on the end of the clutch to ensure the clutch cannot slide off the end of the crankshaft  which can cause failure of the clutch and or damage and injury.
- 1x Clutch Retaining Bolt to suit 25.4mm 1" standard GX390 style crankshaft - secures the clutch to the crankshaft to ensure the clutch cannot slide off the end of the crankshaft  which can cause failure of the clutch and or damage and injury.
** DO NOT USE A STANDARD M10 BOLT IN THE END OF YOUR CRANKSHAFT!   The bolt included in this pack is designed to fit the specialised thread in your crankshaft - using a standard M10 bolt will strip the thread and result in the need to remove the crankshaft and re-install a new one which can be a costly and heartbreaking mistake.
- includes 1x Piston Stop Tool to lock crankshaft so you can tighten the Retaining Bolt (avoids clutch falling off and causing chain breakage and/or injury to the driver/spectators)
Billet aluminium.
SAFE CRANKSHAFT LOCKING TOOL
Our alloy crank lock tool won't damage your piston or crankshaft.  The tool will completely stop the crankshaft rotation and makes the process of removing the clutch locking bolt simple and easy.
WON'T DAMAGE YOUR PISTON FACE!
COMPATIBLE WITH KART ENGINES
CPR crank/piston locking tools work on all engines using standard 14mm x 1.25mm pitch threads as used on almost all karting engines including Honda, Briggs, Rotax, Yamaha and loads of others.
SO EASY TO USE
CPR crank/piston locking tools simply wind into the spark plug hole - just remove your spark plug, wind the crank lock tool all the way in and rotate your crankshaft until it stops.
 It’s really that easy!
CPR PERFORMANCE
CPR products are considered among the most reliable karting components available in the karting industry.  You can rely on our range of tools to help you drive faster.
Crank locking tool (Piston Stop) to enable the fitment and removal of clutches and sprockets to and from Honda, Yamaha and Rotax engines.
Easily remove your clutch and re-install with this simple lightweight and durable tool.  Soft enough not to damage piston surfaces, hard enough to remain reliable.
Use fingers to tighten or 19mm socket.
NEW.  Click the condition meter to learn more about used items.
SKU CLICK3
Regular price: $38.00
Price with FREE DELIVERY: $32.95
