BRAND NEW
***THIS LISTING IS FOR A FACTORY SECOND SET OF RINGS. THEY ARE NOT PERFECTLY ROUND (around 5mm run-out), BUT AFTER SOME USE WILL WEAR ROUND AGAIN - we have decided to offer these at a bargain price so you can pick up a bargain.***
THIS PART NORMALLY RETAILS AT $79
**PLEASE NOTE: There are no returns on this item**
High Density Polyurethane Vinidex Pipe - the best pipe available for slider use. Long lasting, strong, and sized to suit most 11x7.10-5 tyres. Pre-cut 140mm lengths designed to fit over the contact patch of your tyre for maximum retention. INNER DIAMETER - ~273mm, OUTER DIAMETER - ~314mm Professionally cut with Bevelled edges, won't split or crack or wear out in 5 minutes like other PVC pipe. Pair (2 units) Suit 11x7.10-5 Tyres mounted on 210mm or 180mm Rear Rims TYRE AND RIM NOT INCLUDED - Pictured for reference only. This ad is for 2pcs of the rings only.
Why use CPR Tyre Rings for your slider? We've been supplying manufacturers in Australia for several years since the birth of the powered slider. That means we've been learning the right and the wrong products to use when building a reliable slider that won't let you down. There are plenty of cheap solutions on the market, but most manufacturers are either running un-tested products, or products that they know are a compromise and are still happy to sell it to you so that they can rub their hands clean once you've bought your incompatible items. Here at CPR we have developed a range of correctly configured parts that work together with other slider components and readily available go kart parts so that you don't have to do any of the guess-work. Feel free to call us if you'd like to learn more about building a reliable slider. Our tyre rings have been chosen from the best PPE pipe available to give you a nice smooth ride quality with the correct inner diameter to suit most standard go kart rear slicks. The pipe we supply won't last 5 minutes like low quality thin PVC pipe. It won't look 2nd hand like poorly cut pipe, and it won't set you back every cent you have left! Cost effective and long lasting, you'll be the one with the reliable slider that has fun all day long, rather than the guy who spends most of the day repairing his slider.
Condition Meter
NEW - Click the condition meter for more information on condition ratings
Slider Tyre Ring Set PAIR
