Home :: Slider Parts & Kits :: Slider 40mm Axle Kit 8mm Keyway Blue BUDGET series with Pillow Blocks
BUDGET SLIDER 40mm AXLE ASSEMBLY.  EVERYTHING you need to bolt-on and go less a brake disc & hub
HIGH QUALITY ANODISED PARTS
SliderGuide
*New Model (BASIC SERIES) - Suits Powered Slider & Winch Applications. BRAND NEW. SPECIAL OFFER! LIMITED RUN BUDGET SLIDER REAR END! CPR Axle parts are known throughout Australia as being the best quality anodised components available at low prices. We buy in bulk and offer a great range of vivid anodised colours including Blue, Black, Red, Gold and Silver. Scroll down and click the PRODUCT REVIEWS banner below to learn how others have rated our products. You won't be disappointed with this kit! INCLUDES Pillow Blocks so that you can get your project up and running quicker and easier!
The parts in our AXLE ASSEMBLY kits are proper billet go-kart parts, designed for high-speed use at maximum stress. You can buy replacement parts ANYWHERE! INCLUDES 40mm HOLLOW AXLE - HIGH STRENGTH CHROME PLATED (Stronger than a solid shaft but with less weight!) Are you considering a cheap ATV setup to use for your slider? Here are some of the potential pitfalls of using ATV components instead of quality Go Kart components:
WHY USE RACE GO KART PARTS FOR YOUR SLIDER?
ATV: Splined shafts and welded hubs - Parts are usually cheap chinese components designed for small trikes which aren't designed to go fast and won't withstand the forces your slider will require - hard to find replacement parts - most splined products do not fit standard go-kart wheels, - can't relocate the hubs for placement - you'll need to build your slider around the axle - can't fit alternative sprockets - you're stuck with the sprocket and gear ratio you get and you'll need to hunt down a compatible clutch (if it exists) - these are often too tall and willl destroy your clutch - Can't re-size axle shaft - you're stuck with the axle shaft length you get.
GO KART: Standard keyed shaft - All parts are designed for high speed race use - so they are safe. - easy to buy replacement parts, - hubs fit standard go-kart parts (you can buy them anywhere!) - easy to change hub locations (position the axle hubs around your project, instead of making your slider fit around the axle) - Fit any go kart sprocket and get your gear ratio right (you'll have full access to many different pitches and sizes) - Re-size axle shaft for your project - you can cut down the shaft and still fit the wheel hubs wherever you like - all you'll need to do is mill a keyway at worst, or use a peg key!
1x 40mm Axle Shaft
1x 40mm Anodised Sprocket Carrier/Hub)
2x 40mm Low Friction Sealed Bearings)
2x 40mm cast pillow block bearing carriers
F =  ~296mm
PILLOW BLOCKS
Holes are set 67mm apart from each other and 67mm from the centre (Suit Race Go Kart Standard 219 or 35 pitch Sprocket).
DriftTrikeGuideGuide
SKU KSLDR40NB_B
Regular price: $2132.59
$29.90
