Home :: Washers, Spacers, Springs, Nuts & Bolts :: Bolts & Nuts :: Sleeve Reducer 16mm OD 10mmID plus 8mm ID Sleeve Suit STCC2 Stub Axles PK4
BRAND NEW
New Model Sleeve Reducer 16mm OD 10mmID with 8mm ID Bushes STCC2 Suit Stub Axles
Pack of 4pcs
Fits our STCC2 stub axles.  Reduces to 10mm kingpin or 8mm kingpin (when using both bushes)
Inner Diameter 10mm suit M10 Kingpins OR 8mm suit M8 kingpins (using supplied bush)
Outer Diameter 16mm Threaded
Thickness (length) 6mm overall
Designed to be used with 243 Loctite Threadlocker
SKU STCBK1
Go Kart King-Pin Bolt PAIR M8 90mm long High Tensile NEW with Nylocs KINGPIN
$7.95
