Home :: Washers, Spacers, Springs, Nuts & Bolts :: Sleeves / Steering Spacers :: Sleeve Reducer 14mm OD 8mmID Suit Stub Axle Brackets and Frames PAIR
BRAND NEW Sleeve Reducer 14mm OD 8mmID Suit Stub Axle Brackets and Frames
PAIR (2pcs)
Fits our BRSC02 stub axle brackets and  frames (ackerman points / stub axle / spindle mounts) with 14mm holes.  Reduces to 8mm kingpin.  Can also be interchanged with our Camber/Castor adjuster set CMBC01 and CMBC02
Two locking holes pre-drilled to suit BRSC02 C-Clamp brackets
Inner Diameter 8mm suit M8 Kingpins
Outer Diameter 14mm
Thickness (length) 8.5mm overall, top flange = ~2.75mm, sleeve protrusion (part that fits inside the 14mm hole) = ~6mm
BRAND NEW
SKU SPCS148
Bracket for Stub Axle Spindle suit STAC01 Spindle Stub Axle Kits (14mm Hole)
$16.90
