Home :: Engines, Carbs & Parts :: Side Plate (Clutch / Drive Sprocket guard cover) suit 4-Stroke Engine LIFAN Honda Clone
Side Plate (Clutch / Drive Sprocket cover) to suit our 4-Stroke Engine LIFAN Honda Clone
This plate will ensure you comply with rules and regulations for covering the engine side of the drivetrain on your honda clone engine.  Designed to cover clutch and drive sprocket, all the way to the rear sprocket if the engine is mounted close to the rear axle.
Bolt-on complete simple fitment for our LIFAN 6.5HP engines - also bolts onto most other clones.
Brand New Side Plate (Clutch / Drive Sprocket cover) suit 4-Stroke Engine LIFAN Honda Clone
SKU ENSP65
