Home :: Axles & Parts :: 30mm :: Shaft-Less 30mm Axle Kit 6mm Keyway Gold Anodies Premium Billet Hubs
*THIS KIT DOES NOT INCLUDE AXLE SHAFT*
SHAFTLESS 30mm AXLE ASSEMBLY.  JUST ADD AN AXLE SHAFT and bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
1x 30mm Anodised Brake Hub
1x 30mm Anodised Sprocket Carrier/Hub
2x 30mm Low Friction Sealed Bearings
2x 30mm Anodised Self-aligning bearing carriers
2x 30mm Anodised Wheel Hubs
Not included
30mm low friction free-spin bearings
Self-Aligning Bearing Flange/Holder/Cradle complete with 30mm Low Friction Race Bearing installed.
Holes are set 68mm apart from each other and 45mm from the centre.
Length: 90mm
Holes are set 78mm apart from each other and 67mm from the centre (Suit Standard 219 or 35 pitch Sprocket).
SKU AXSLC3G
Regular price: $471.16
Price with FREE DELIVERY: $299.00
$24.90
