Home :: Axles & Parts :: 40mm :: Shaft 40mm Axle 8mm Keyway 1050mm Medium (Fautly)
****  THIS SHAFT HAS INCORRECT RUN-OUT.   About 10%-20% of shaft needs to be rubbed back to make it the correct diameter.  It's only very slightly over due to a poor chrome finish.  Easy to fix, and cost effective for cut down shaft length required by drift trikes, winches, etc ****
40mm AXLE Shaft only.
Medium grade.
1050mm Long.
8mm Keyways for 2-stroke and 4-stroke application.
Comes with 4x Keys.
Axle Length: 1050mm
Keyway locations:  from end to end:
This quality part is the same item used in our 40mm Complete Axle Kits.
SKU AXSC408_FLTY
