Home :: Axles & Parts :: 40mm :: Shaft 40mm Axle 8mm Keyway 1050mm Medium - 4keys + Peg Key
40mm AXLE Shaft only.
Medium grade.
1050mm Long.
8mm Keyways for 2-stroke and 4-stroke application.
Comes with 4x Keys + 1 peg key
Axle wall thickness: 3.5mm
***NOTE: INBOARD SPROCKET POSITION IS NOT INCLUDED WITH THIS SHAFT***
F =  ~296mm
This quality part is the same item used in our 40mm Complete Axle Kits.
SKU AXSC408_4KPEG
