GUIDE
Servicing NORAM Cheetah Clutches - Disassembly and Assembly Tutorial
This month we're showing you how to break down and re-assemble your NORAM Cheetah twin disc clutch, and we'll also give you the tips and tricks to service it and keep it in the best operating order.
CONTENTS
1. Remove the Engagement Adjustment Screws
2. Remove the Lever Support Plate
3. Dis-assemble the Lever Support Plate
4. Remove the Pressure Plate assembly
5. Remove the first Friction Disc
6. Remove the Floater Disc
7. Remove the second Friction Disc
8. Separate the Basket & Drive sprocket assembly from the Transmission Gear assembly
9. Dis-assemble the Transmission Gear assembly
10. Dis-assemble the Basket and Drive Sprocket assembly
We have been advised officially by Noram that standard BRAKE CLEANER CAN BE USED TO CLEAN ALL SURFACES - specifically friction disc, housing, transmission plates etc. Remember to grease any surfaces which require lubrication prior to assembly.
Remove the clutch from your kart and clean off any debris and excess chain lube, inspect keyway for wear or deformaties
Position the clutch sitting on the sprocket.
Measure the spring height on each spring and record your height, then remove bolts washers and springs. Stock setting is approximately 5 turns out.
Using an allen key tool, remove the 6 spring loaded adjustment screws.  (Replacement part: CLCHP21 )
Remove the 6 Lever Support Plate retaining bolts using an allen key tool.  (Replacement part CLCHP00 )
*NOTE: Make sure you perform this step somewhere enclosed, like a box or a plastic ice-cream container in case the levers fall out - you can easily lose dowel pins if they fall out and are not contained*
Carefully lift the Lever Support Plate (Replacement part CLCHP18 ) up and away from the Cheetah body. Flip the plate as soon as it is clear of the body - do not use jerky movements so as to avoid the levers from falling out. Place carefully on a surface, preferably in a container like an empty plastic ice cream container, or a bucket, or similar vessel.
Check the plate for any wear.
*NOTE: Perform this step in a container if possible to avoid losing the dowel pins - you cannot re-assemble the Cheetah clutch without them!
Remove the 6 Levers (Replacement part CLCHP16 x6 ) by pulling them upward with the lever support plate facing downwards as per the last step.
