Home :: Tools, Starters & Chargers :: Tools :: Rod Bearing clearance measuring tape guage plastigage 150mm length
Guage for use with rod bearings.
Use this if you're installing any of our conrods to ensure you have the right clearance.  Too much or too little will cause premature engine failure.
A must have if you're doing your own rod bearings.
NEW.
SKU EGPGC1
Conrod for Honda GX200 GX160 & Honda Clone Billet Genuine ARC
Conrod for 212cc Predator (Hemi & Non Hemi) or Torini or Predator Clone Billet (+0.20) (suits predator flat-top piston) Genuine ARC
Conrod for Honda GX200 GX160 & Honda Clone Billet Genuine ARC Conrod for 212cc Predator (Hemi & Non Hemi) or Torini or Predator Clone Billet (+0.20) (suits predator flat-top piston) Genuine ARC
$199.00
$199.00
Conrod for Honda GX200 & Honda Clone Billet (+0.020) (also suits predator flat-top piston) Genuine ARC
Conrod for Honda GX200 & Honda Clone Billet (+0.10) Genuine ARC
Conrod for Honda GX200 & Honda Clone Billet (+0.020) (also suits predator flat-top piston) Genuine ARC Conrod for Honda GX200 & Honda Clone Billet (+0.10) Genuine ARC
$199.00
$199.00
Conrod for Honda GX200 & Honda Clone Billet (Stroker)
Conrod for Honda GX200 & Honda Clone Genuine CPR OEM (Standard high grade Stock Replacement suit ST1, also fits GX160)
Conrod for Honda GX200 & Honda Clone Billet (Stroker) Conrod for Honda GX200 & Honda Clone Genuine CPR OEM (Standard high grade Stock Replacement suit ST1, also fits GX160)
$199.00
$19.95
Bearing - ARC Conrod replacement bearing GX200
Bearing - ARC Conrod replacement bearing (Predator Type)
Bearing - ARC Conrod replacement bearing GX200 Bearing - ARC Conrod replacement bearing (Predator Type)
$69.95
$59.95
Bearing - ARC Conrod replacement bearing (Suits Stroker Crank Conrod CRG2ST)
Bolt Set - ARC Conrod replacement bolt pair GX200/MITSUBISHI/VANGARD 6hp
Bearing - ARC Conrod replacement bearing (Suits Stroker Crank Conrod CRG2ST) Bolt Set - ARC Conrod replacement bolt pair GX200/MITSUBISHI/VANGARD 6hp
$39.95
$39.95
Bolt Set - ARC Conrod replacement bolt pair GX270-GX390
Conrod for Honda GX270 9hp Honda Clone Billet Genuine ARC
Bolt Set - ARC Conrod replacement bolt pair GX270-GX390 Conrod for Honda GX270 9hp Honda Clone Billet Genuine ARC
$47.95
$299.00
Conrod for Honda GX340 GX390 & 420 Predator or Honda Clone Billet Genuine ARC
Conrod for Vanguard 6hp 6.5hp / Briggs Mitsubishi Modell 11 Billet 3.465" Genuine ARC
Conrod for Honda GX340 GX390 & 420 Predator or Honda Clone Billet Genuine ARC Conrod for Vanguard 6hp 6.5hp / Briggs Mitsubishi Modell 11 Billet 3.465" Genuine ARC
$389.00
$199.00
