Home :: Clutches :: Red Clutch Needle Roller Sprocket Bearing suit Short Shaft Extended 9T Sprocket for KT100S
This is the bearing that sits in the flange on the clutch drum end of the sprocket.   You will also reqiure a bush (see related items) unless you are re-using your old one.  Some older models of the extended sprockets have a different size bearing - if yours is smaller you'll need a bush with this bearing.
24x28x9.8mm
SKU BCRCS9
Red Clutch BUSH for 9T Extended Sprocket Bearing suit Short Shaft KT100S
$19.95
