Home :: Clutches :: Red Clutch Drive Sprocket Clutch Bearing SET (Pair) suit Short Shaft KT100 10T Sprocket (current spec 4 style)
Bearing Pair to suit Red Clutch Short Shaft 10T Spec 4 (current model)
Bearing is 26mm OD, 17mm ID, 5mm thick
SKU BCRC10
