Home :: Clutches :: Red Clutch BUSH for 9T Extended Sprocket Bearing suit Short Shaft KT100S
This is the bush that sits inside the larger bearing that goes inside the large flange on the drum end of the extended sprocket.
OD 24mm
ID 13.50mm and 12.20mm (staggered ID)
THICKNESS 10.00mm
SKU BCRCB9
