Home :: Axles & Parts :: 25mm :: Rear Wheel Hub Hubs Pair 25mm Orange (Short, faulty drilled incorrectly)
*NOTE: THESE HUBS ARE DRILLED INCORRECTLY TO SUIT 3x42mm - can be re-drilled to suit 3x50mm.
SUPPLIED WITH 3D-PRINTED TEMPLATE TO MAKE IT EASY TO MARK THEM FOR DRILLING & TAPPING.
Slot the guide onto the top of the hubs and use the small holes to mark the positions of the 3x50mm PCD centres.  The guide can be held in place with the 3x screws (M6 screws not inlcuded)
Some marks and scratches on some units.
Premium quality CPR Billet Aluminium Hub Pair
Axle Size: 25mm
Keyway Size: 6mm
Locking Bolts included
Length: 42mm
Anodised: Yes
CNC Machined Alloy
Colour: As Per Title & Pictures
THESE HAVE BEEN DRILLED INCORRECLTY AT THE FACTORY - Holes are set 42mm apart from each other (WILL NOT Suit Standard Rear Wheels).
Brand new CNC Anodised Hubs with Brand New studs and nyloc nuts.
SKU WHC25O_SF
