Home :: Axles & Parts :: 25mm :: Rear Wheel Hub Hubs Pair 25mm Orange
Premium quality CPR Billet Aluminium Hub Pair
Axle Size: 25mm
Keyway Size: 6mm
Locking Bolts included
Anodised: Yes
CNC Machined Alloy
Colour: As Per Title & Pictures
Brand new CNC Anodised Hubs with Brand New studs and nyloc nuts.
*NOTE: If using this item with our WAF78 or WAF110 adaptor plates, use shorter screws (maximum 16mm length) due to slightly shallower threads than other hubs.  If you are using studs on your application (like a race kart with standard kart wheels) then this is not applicable.
SKU WHC25O
