Home :: Axles & Parts :: 40mm :: Rear Wheel Hub Adaptor Adapter PAIR suit all CPR Rear Wheel Hubs - Convert to 4x Stud 110mm PCD (Garry)
Rear Wheel Hub Adaptor PAIR (Does NOT include wheel hubs - pictured for reference only)
OD of adaptor is approx. 130mm
Thickness of adaptor is approx 10mm
Designed for using ATV Style wheels on standard Go Kart hubs.
IMPORTANT: When fitting wheels, the adapters need to be fitted to your existing hubs and then the wheels are fitted to the adapters. YOU MUST MAKE SURE ALL BOLTS & SCREWS ARE VERY TIGHT! Loose bolts/screws can cause the hubs and adapters to become loose, which can damage threads in hubs or damage the mounting holes in the wheels - this accelerates wear and will result in complete failure.
SKU WAF110_Garry
