Home :: Wheel, Tyres & Front Hubs :: Rear Wheel Hub Adaptor Adapter PAIR suit all CPR Rear Wheel Hubs - Convert to 3x Stud 78mm PCD
Rear Wheel Hub Adaptor PAIR (Does NOT include rear wheel hubs - pictured for reference only)
Holes are set 50mm apart from each other and 29mm from the centre (Suit Standard Rear Wheels) and plate holes are 78mm from each other (78mm x3 PCD)
OD of adaptor is approx. 107mm
Thickness of adaptor is approx 8mm
Designed for using ATV Style wheels on standard Go Kart hubs.
IMPORTANT: When fitting wheels, the adapters need to be fitted to your existing hubs and then the wheels are fitted to the adapters. YOU MUST MAKE SURE ALL BOLTS & SCREWS ARE VERY TIGHT! Loose bolts/screws can cause the hubs and adapters to become loose, which can damage threads in hubs or damage the mounting holes in the wheels - this accelerates wear and will result in complete failure.
SKU WAF78
