Home :: Chassis Parts :: Crash bars and linkages :: Rear Crash Bar
Rear Crash Bar
Rear Crash Bar
Rear Crash Bar
Suits older model karts.  (angled from front of kart, perpendicular from rear)
Dimensions:
Width of bar (extremes):  approx 520mm
Centre of the mounting tube to centre of mounting tube (centre-centre mounting if removing the bolt-on mount and using a tube-mount system) 500mm
Bracket - Bracket dimensions - Centre hole to centre hole = 500mm, Innermost hole to innermnost hole = 435mm, Outermost Hole to Outermost Hole = 565mm
Tube diameter of tube-mount bar (OD 30mm)
This bar has a bolt-on bracket welded, but you can cut the bracket off and cut the front of the tube to fit using tube-mounts.
Brand New.
SKU CRCBC2
