Home :: Plastics & Numbers :: Rear Bumper Bar suit PSCC1 New-Style Plastics Kit
Pictures to come soon.
*New Model rear bumper bar.  Can be used for both 2 stroke and 4 stroke kart applications.
Protect your rear end from other competitors.
Dimensions
*NOTE: Mounting hole is slotted - 25mm wide ~15mm diameter
A - overall length = 1350mm
B -  as per lower picture - inside distance between where the bar sits behind the rear wheels. = ~970mm
C - Mounting holes centre to centre distance = ~700mm
D - Width of each side that sits behind the rear wheels = ~190mm
E - Distance between outermost edge, and centre of mounting hole = ~325mm
F - Distance from outermost extreme (where numbers are fixed) to inside face of the section that sits behind the rear wheels = ~220mm
G - Distance from outermost extreme (where numbers are fixed) to outermost section of main bar = ~80mm
H - Distance from inside face of the section that sits behind the rear wheels to outermost section of main bar = ~140mm
I - Height of bar (total) from lowermost point to highest point = ~170mm
Brand New.  *New Model plastic setRear Bumper Bar suit PSCC1
7%
SKU PSRC1
