Home :: Racing Simulator Parts & Retro Computing :: Racing Cockpit Rig RPM Club without Seat or Screen Mount
   BARE CHASSIS ONLY
Seat, Electroncis and Screen Mount not included - Bare Chassis only.  Great for DIY - add your own seat and enjoy!
  Extreme Strength & Rigidity
Our RPM Club series chassis has been engineered to provide premium grade strength and rigidity.  These are hands-down one of the most rigid and strong chassis on the market right now compared to most other popular brands.  Box section steel ensures virtually no flex, allowing the addition of high-power professional direct drive steering systems and other peripherals where strength of chassis is critical to performance. Quality powder-coated components provide extended life and ensure your chassis gives you years of trouble free operation and excitement.
  35mm Square Tubing for Super-High rigidity.
  High tensile locking bolts reduce loosening from vibration.
   Fully Adjustable
With a dazzling array of adjustments, the RPM Club chassis can be manipulated to suit almost any driver for a comfortable and immersive experience.
  Fully adjustable seat back/forwards & backrest angle.
  Steering wheel height and screen height (with optional screen mounts).
  Chassis length & pedal height/angle adjustment.
Our RPM Club series chassis has been engineered to provide premium grade strength and rigidity.  Quality powder-coated components provide extended life and ensure your chassis gives you years of trouble free operation and excitement.
 Flaw-less black powder-coating for premium rust resistance.
  Strong enough to accommodate high-torque & direct drive steering wheels.
   Compatible
*STEERING WHEEL FOR ILLUSTRATION ONLY - NO ELECTRONICS INCLUDED IN THIS KIT
Designed for use with popular steering wheel, pedal and shifter packages so you can get racing right-away!
  Pre-drilled ready for Logitech G25, G27 & G29.
 FAST & Easy to set up
Our RPM Club series chassis has been carefully planned so that it’s fast and easy to assemble.  The Club TV model takes around 10-15 minutes to assemble making it a breeze to set up – start racing sooner!
  Simple slot & lock system used on the entire frame is fast and easy.
  Only requires a 10mm and 13mm spanner – all other tools included.
 Solid double-bolt locking system improves rigidity and strength.
Brand New.
18%
SKU RPMCHAS
Market price: $399.00
Sidepods Sidepod Bars Pair suit older style karts and pods
$79.00
