Home :: Racing Simulator Parts & Retro Computing :: Racing Cockpit Rig RPM Club with Triple (3-Screen) Mount
  Extreme Strength & Rigidity
Our RPM Club series chassis has been engineered to provide premium grade strength and rigidity.  These are hands-down one of the most rigid and strong chassis on the market right now compared to most other popular brands.  Box section steel ensures virtually no flex, allowing the addition of high-power professional direct drive steering systems and other peripherals where strength of chassis is critical to performance. Quality powder-coated components provide extended life and ensure your chassis gives you years of trouble free operation and excitement.
  35mm Square Tubing for Super-High rigidity.
  High tensile locking bolts reduce loosening from vibration.
 Flaw-less black powder-coating for premium rust resistance.
 Modular Screen Mounts
RPM Club Chassis modular system allows you to run the cockpit with or without the adjustable 1 to 3 screen mount.
  Base unit without screen mount is perfect for the lounge room.
  Screen mount provides single or 3-screen mounting options.  Supports up to 3x 27" screens.
   Fully Adjustable
With a dazzling array of adjustments, the RPM Club chassis can be manipulated to suit almost any driver for a comfortable and immersive experience.
  Fully adjustable seat back/forwards & backrest angle.
  Steering wheel height and screen height (with optional screen mounts).
  Chassis length & pedal height/angle adjustment.
   Compatible
*STEERING WHEEL FOR ILLUSTRATION ONLY - NO ELECTRONICS INCLUDED IN THIS KIT
Designed for use with popular steering wheel, pedal and shifter packages so you can get racing right-away!
  Pre-drilled ready for Logitech G25, G27 & G29.
 FAST & Easy to set up
Our RPM Club series chassis has been carefully planned so that it’s fast and easy to assemble.  The Club TV model takes around 10-15 minutes to assemble making it a breeze to set up – start racing sooner!
  Simple slot & lock system used on the entire frame is fast and easy.
  Only requires a 10mm and 13mm spanner – all other tools included.
 Solid double-bolt locking system improves rigidity and strength.
 Compact Size & Folding Seat
The super-small footprint of our chassis means you can stow it away easily then slide it back out ready for racing action!
  Footprint 90cm Long x 51cm Wide with pedal base removed.
Brand New.
SKU RPMCP3
Price with FREE DELIVERY: $9999.00
