Home :: Engines, Carbs & Parts :: Race Spec Header Pipe suits MTARLV for 4-Stroke Engine LIFAN OHV 6.5hp 192cc GX200 GX160
Race Spec Exhaust Header Pipe.
Proven race winning header.
ADD EXTRA HP!
 Suits Tip inner diameter approx 34mm.
This item will significantly improve breathing and heat transfer.  This item is currently being used on competitive karts nationally and in the USA.
Pipe ID is 24.5mm at the flange, steps up to ID 30.5mm where the tip goes on.
OD is 27mm at the flange and OD is 34mm where the tip goes on.
Dimensions as per last detailed image:
A = ~200mm
B = ~300mm
C = ~340mm (overall length in a straight line from header pipe end to head mating flange)
SKU MTHRLVN
