THIS KIT DOES NOT INCLUDE CHASSIS, RELEVANT BARS OR ENGINE OR ENGINE MOUNT. IT ALSO DOES NOT INCLUDE BRACKETRY FOR THE PLASTICS OR SEAT STAYS. *NOTE: An engine and engine mount can be optioned into the kit if required. Here is a run down of the main components. All bolts, are included to complete the kart. 1. THERE IS NO CHASSIS (frame) OR CRASH BARS (front crash bar, rear mounting bars, sidepod mounting bars, seat uprights) included in this kit. This kit is designed for building your own frame. 2. Pedals, bolts and pedal return springs 3. Steering Assembly including steering wheel and all nuts and bolts/spacers etc to fit. 4. Stub Axles and all nuts and bolts/spacers etc to fit. 5. Brakes and bolts to fix to chassis 6. Brake Rod, pins and split pins 7. Complete rear axle assembly includes two bearings all nuts and bolts including disc. 8. Complete set of front and rear wheels with tyres 9. modern style nosecone and nassau plastics without brackets and fittings, with rear plastic bumper bar 10. Seat 11. Complete bolt kit including springs, fittings, spacers, etc etc 12. Assembly Guide 13. Fuel tank and lines, assoicated hardware
New. Brand New (DIY ASSEMBLY KIT) |
| SKU | RTNC | |
| Base product price: |
$9999.00
including GST 10% |
