Home :: Engines, Carbs & Parts :: Carbs & Related Fuel parts, Manifolds :: RK114HL Overhaul Kit with Pop Off Spring suit Comer S80 SW80 Tillotson Carb
Carburettor overhaul kit (seal kit) as pictured.
Aftermarket to suit Tillotson carb.
This is the COMPLETE overhaul kit, not the standard kit, or the diaphragm only kit.  Make sure you get all the parts you need, rather than scratching your head wondering where they are when you pop the top off your carb.
Suit COMER S80 SW80 Tillotson Carbies.
THIS MODEL INCLUDES THE POP-OFF SPRING
INLCUDES POP-OFF Spring.
Does your carbie seal properly? Do you hold pressure on pop-off? If you don't, or you're not sure, you need to replace your needle. Cheap and effective way to maximise horsepower and correct starting problems.
Carby RK-114HL_Plus Overhaul Kit with Pop Off Spring suit Comer S80 SW80
40%
SKU RK114HL_PLUS
