Home :: Engines, Carbs & Parts :: Engines :: Push Rod Chrome Moly Race - Single Unit CUT TO LENGTH TYPE - CPR Performance suit ENCL65 and Honda GX160/200 clones
*CUT TO LENGTH MODEL - these require shortening and pressing of the ball end to suit application.
*We highly recommend the use of our CPR Performance Guide Plate with these pushrods.
When you're taking your LIFAN 6.5hp engine or Honda GX160/200 clone engine to the limit with Intake, Exhaust, and Fuel mods.  Our precision made Chrome Moly CPR Performance pushrods are the ideal solution when increasing rev range by addition of extreme upgrades and removal of governors on your Honda clone engine.
CPR Performance Chrome Moly push rods are the most affordable strong and light push rods available on the market for 160/200 Honda GX, and Clone engines.
These push rods are shipped with a ball tip pushed into one side of the tube so they can be shortened. They are machined to standard length but can be easily shortened up to 1/4" by simply cutting the tube down on a lathe or sander. These push rods can be used with any of our valve springs.. (154.8mm long with approx 6.5mm extra length with ball end installed, 4.85mm thick)
Price is for a single unit.
NOTE: Any method can be used to cut the rod, but it is most accurately done using a lathe. Once cut, file or sand smooth the end and then ensure there are no burrs on the inside of the rod. Use a small drill bit to de-burr the inside before installing the rod end. The rod end should be firm to install but should be able to be pushed in by holding the rod in one hand, and using a press (or tapping with a nylon hammer) until all the way home. If the de-burring step is skipped, the rod end will not go all the way in and the pressure needed will bend the rod.
PushrodLengthGuide
SKU EPRB02
