Home :: Engines, Carbs & Parts :: Push Rod Chrome Moly Race - Single Unit - CPR Performance suit Honda GX240 - GX390 and clones (Cut To Length)
When you're taking your Honda GX240-390 clone engine to the limit with Intake, Exhaust, and Fuel mods.  Our precision made Chrome Moly CPR Performance pushrods are the ideal solution when increasing rev range by addition of extreme upgrades and removal of governors on your Honda clone engine.
CPR Performance Chrome Moly push rods are the most affordable strong and light push rods available on the market for 240-390 Honda GX, and Clone engines. These push rods can be used with any of our valve springs.
Price is for a single unit.
CUT TO LENGTH MODEL (these are about 20mm longer than a standard rod and can be cut/filed down to suit)
FITS:  All Honda GX240-390 engines & Clone engines.
Ball-End: 5.9mm
Length: approx 193mm with ends
NOTE: Any method can be used to cut the rod, but it is most accurately done using a lathe.  Once cut, file or sand smooth the end and then ensure there are no burrs on the inside of the rod.  Use a small drill bit to de-burr the inside before installing the rod end.  The rod end should be firm to install but should be able to be pushed in by holding the rod in one hand, and using a press (or tapping with a nylon hammer) until all the way home.  If the de-burring step is skipped, the rod end will not go all the way in and the pressure needed will bend the rod.
PushrodLengthGuide
SKU EPRB39C
