Home :: Powered Slider Trike Complete Rear End Kit (NO TYRES)
*PLEASE NOTE - Current stock has sligthly different colour flywheel cowling and pull start cover - engine is identical internally and externally aside from the paint colour* - see last picture in the set
NO TYRES INCLUDED IN THIS KIT
ABSOLUTELY BRAND NEW complete slider rear end kit! Bolt-on and GO!
All nuts and bolts are included to connect up the rear end.
Includes:
1x Complete 40mm project axle kit (Your choice of colour - Black, Blue, Gold, Silver or Red)
1x 40mm Axle Shaft ($120)
1x Drilled Brake Disc ($120)
2x CPR Bearing Hanger Brackets ($49.80)
ALSO INCLUDES the following nuts, bolts, and fixations:
Axle Length: 1050mm
Keyway locations:  from end to end:
@ 10mm->75mm
@ 120mm -> 185mm
@ 350mm->400mm
@ 740mm->790mm
@ 975mm -> 1040mm
1x Complete CPR 10hp High Output 200cc GX200 Style Engine with clutch and throttle cable fitted (your choice of clutch sprocket)
Are you looking for a simple & easy solution to powering a slider?  Ideal starting point for racing or recreational use, our LIFAN Honda Clone engine is one of the best built, most reliable available in Australia.  We buy the best quality clone available today with quality automotive grade components inside.  It comes complete, ready to run with throttle cable and clutch already attached.  All you need to do is mount it to your frame - can be easily adapted to any 2-stroke mount with an adaptor plate.
Planning on upgrading your engine later?  Don't get stuck with a poor flowing head, start with our engine as a base and ensure you have the best flowing head on the track for all box-stock categories where porting is not allowed.  If you're going to port anyway, why not start with a better design so your work is even more rewarding?
Lifan equipment will keep you running. All Lifan engines are Industrial Grade and feature cast iron sleeves, automotive grade rods, pistons, rings, crankshafts, valve and valve springs.The Lifan Overhead Valve (OHV) design provides better fuel efficiency, quieter operation, and longer life. The 196 CC Horizontal Shaft Engine is ideal for go kart use.  The Overhead Valve (OHV) design provides fuel efficiency, quiet operation, and a long life. The engine features a horizontal-shaft design for go-kart use.
68 mm x 54 mm bore/stroke
Horizontal output shaft
~4L fuel tank capacity offers long run times
Force-Air Cooled
Our NEW performance pre-built engine has just arrived.  Identical to our standard engine with the complete upgrade kit fitted (inlet & exhaust) with all panels and external fuel pump, this engine is ready to race out of the box.   Even the governor has been removed for your convenience.
This unit is supplied with #35 Clutch (number of teeth as per title) and Throttle Cable to suit all go-kart pedals, Toolkit and owners manual with all setup details including valve clearances etc.   A comprehensive package.
1x CPR #35 Chain and Axle Drive Sprocket (your choice of axle drive sprocket)
1x CPR Recreational Hydraulic Brake System
1x Cable to connect Hydraulic Brake Master to hand controller (throttle cable) and terminator (Colour of your choice)
NO TYRES INCLUDED IN THIS KIT (1x pair rear wheel rims your choice of rim style or type)
Choose between 130mm, 180mm, 210mm solid-style or 210mm mag-style rear rims.
Comes with everything you need to connect it up and use.
Just add Frame, Seat, Front wheel and hand controls and you're in sliding!
SKU KSLDR1
Base product price: $1449.00
